Displays a table of the current Link-State Database (LSDB) statistics.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| all | Specifies all OSPFv3 areas, IPv6 configured VLANs, or IPv6 tunnels. |
| vlan_name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| link | Link LSA. |
| router | Router LSA. |
| network | Network LSA. |
| inter-prefix | Inter Area Prefix LSA. |
| inter-router | Inter Area Router LSA. |
| intra-prefix | Intra Area Prefix LSA. |
| nssa | NSSA LSA. |
| as-external | AS External LSA. |
| lsid_address | Specifies the link state ID of the LSA. |
| router_identifier | Specifies the router identifier of the advertising router. |
Display in summary format.
ExtremeXOS provides several filtering criteria for the show ospfv3 lsdb stats command. You can specify multiple search criteria and only the results matching all of the criteria are displayed. This allows you to control the displayed entries in large routing tables.
A common use of this command is to omit all optional parameters, resulting in the following shortened form:
The shortened form displays all areas and all types in a summary format.
You can filter the display using either the area ID, the remote router ID, or the link-state ID. The default setting is all.
The following command displays all areas and all types in a summary format:
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
